Previous in Forum: Gleason vs Cyclo-Palloid Spiral Bevel Gears   Next in Forum: Subaru Driveshaft (Propshaft for Those in UK :))
Replacement Rivet Types for Aluminum Boat Restoration
06/18/2012 6:56 AM
what replacement rivet types are most successfully used for aluminum boat restoration ?
I need to use a pull through type rivet. that would be leak proof............billchep
Re: billchep
06/18/2012 7:07 AM
Re: billchep
06/18/2012 7:12 AM
View Our Rivet Selection »
Blind rivets are available from various sources. I'd coat them with silicone, but it isn't absolutely necessary.
Holes that are enlarged should be drilled out and a larger rivet used to prevent leaks and loosening.
Closed-End Blind Rivets
The two happiest days in a boat owner's life are the day he gets the boat and the day he gets rid of the boat. I mostly agree with this.
Good luck.
Register to Reply 2 comments
