Previous in Forum: False Floor Shearing Stress   Next in Forum: Furnace Oil Testing at Construction Site
India - Member - Atul Singla Engineering Fields - Piping Design Engineering - Atul Singla- INDIA Engineering Fields - Mechanical Engineering - New Member
Underground Lines Around Pipe Rack
06/18/2012 8:09 AM
While routing the underground lines along the piperack which one is best option :
1. Lines should be routed parallel (on one side) to the piperack (i.e. more space is required)
2. Lines should be routed under the piperack (i.e. space can be saved)
Atul singla
Good Answers: 34
Re: Underground lines around Pipe Rack
06/18/2012 11:35 AM
Always or almost always, are installed parallel to the pipe rack. In the case of fire water lines on both sides. Anyway, you can get some data in ASTM-2321-11 and API 1166. I do not think you get much more. Sorry.
Re: Underground Lines Around Pipe Rack
06/19/2012 12:53 AM
I'm not sure any Code governs this, but consult your local regulations.
If the pipes are hot, electrical lines above might also overheat.
If the pipes are cold or leaky, electrical lines below might get wet.
Other than that, convenience might be the best guide.
In all of these cases so far, the lines are parallel....
Register to Reply 2 comments
