Previous in Forum: ASME U Stamped Pressure Vessel Assemble at Site   Next in Forum: Hammer Blind
Fg Wilson Engine p1375e3
06/20/2012 1:18 PM
Dear buddies I have an problem on Fg wilson engine model p1375e3 engine does not start ,when I press start. It begins cranking half round and stops showing fault as 'airflap closed' but air flaps are remaining open. every attempts showing same fault. Anybody can help?
Pathfinder Tags: diesel engine
Re: Fg Wilson Engine p1375e3
06/27/2012 4:21 AM
Check the control system,most probably the signal from the proximity sensor/any sensor that shows the flap wings position mght be mal functioning so it will not start.So just check the controls.
have you also tried starting while the flap wings are closed
01/12/2024 8:23 AM
<...Anybody can help?...>
Sure. These people can. Give them a call.
Register to Reply 2 comments
