Previous in Forum: Electronics   Next in Forum: About MNS iS ABB
What is the Autonics ct400-1p Timer on Lapmaster Lapping & Polishing Machine Def
06/22/2012 4:45 PM
I recently buy a lapping/polishing machine and by mistakenly the timer/counter settings/parameters has been changed i try to fix back with the manuals but i found there is no descriptions of default factory settings.i want to use the timer/counter to set the time around 20 minutes so when its start i will be off after 20 minutes automatically.by the way at this time i cannot set the time and i have to push button 2 to 3 times to start the machine.the push button is not faulty only the settings are out that way its happening.I try to contact with the lapmaster but they did not reply.so plz guys help me out to set the default company settings/parameters/values.the machine is 400v 50HZ and around 2KW.
www.autonicsonline.com/pdf/counter_tota1_7th.pdf
www.autonics.com/9th_selection_guide.pdf
www.lapmaaster.com/machinery/default.htm1
Re: What is the Autonics ct400-1p Timer on Lapmaster Lapping & Polishing Machine Def
06/23/2012 12:16 AM
Factory default settings for the timer itself are on page A-12.
However, since this is only a component for the Lapmaster, Lapmaster has probably programmed in its own settings to make the entire system work correctly.
Unless you have some literature from Lapmaster that gives this info, you will have to contact Lapmaster directly.
Good luck
06/23/2012 3:49 AM
thanks and i am trying from almost 1week to contact them but the did not reply to my email that why i came here to share my problem with you guys.
Register to Reply 2 comments
