Previous in Forum: Graphical Method   Next in Forum: Heat Exchanger (Shell & Tube)
Selection Motor HP and Gear
06/26/2012 11:54 AM
hello everybody,
i want to lift a load of about 750kg at the speed of 0.2m/sec by drum and rope at a height of 12mtrs.
pl guide me the selection of gear, drum dia and motor hp
thanking you
orkay
Re: Selection Motor HP and Gear
06/26/2012 1:46 PM
(0.2 x 3.2808 x 60)(750 x 2.2)/33,000 ≈ 1.96 ≈ 2hp theoretically. Because of accelerating the load, you would need a 3hp or 5hp motor.
Depending on how frequent the usage is, the drum diameter should be something like 10x to 20x the cable diameter. From that you can calculate the rpm of the drum, and then the gear ratio to match the rpm of the motor. The output torque of the gear will be 750kg x radius of cable wrap on the drum x safety factor of maybe 2.0.
Alternatively, purchase a winch from a catalog.
06/27/2012 12:44 AM
I appreciate if you elaborate the formula use. I calculate as below
Power = Force* distance /time
=750*9.81*12/(12/0.2)
= 1471.5 W
= 1471.5/745.6 hp (1 hp =745.6W)
= 1.97 hp
≈ 2 hp
Amazingly it matched
RK
06/27/2012 2:30 AM
My calc used imperial units, based on 1 hp = 33,000 ft-lb/min. The upsize to 3 or 5 hp is kind of an experience estimate; coincidentally it matches some fish unloading hoists in my plant.
06/27/2012 9:51 AM
Register to Reply 4 comments
brkmech (1); lyn (1); Tornado (2)
