Previous in Forum: AVR Design for 3 Phase Generator 50kva   Next in Forum: Heat Sinking an LM338T Voltage Regulator
Calculation of KWH Reading of Energy Meter
06/29/2012 10:34 AM
hello everybody, i have a energy meter rated PT-66kv/110v,CT-200/1A,accuracy class0.5 and multiplt factor-1000 export type connected on 66kv feeder having CT Ratio 100-200-400/1A .what will happen to the kWH reading if i connected this meter to the 400/1A for the calculation of units consumed in the feeder.if i multiply it by 2000 to get the correct reading of the unit consumed.as the meter is design on the CT ratio -200/1A.please tell me about this.
Good Answers: 181
Re: Calculation of KWH Reading of Energy Meter
06/29/2012 11:48 PM
Could I ask why you would want to do this?
06/30/2012 12:35 AM
i want this because i connect the energy meter in the grid station on the 66kv out going feeder on 400/1A
07/01/2012 11:16 AM
Simple formula you can apply to calculate the Multiplication factor of meter system
Multiplication factor for KWH = CT ratio of line * PT ratio of line
___________________________ * scale factor of meter
meter CTR * meter PTR
Exploring the Science of Electricity
07/02/2012 12:16 AM
please illustrate this formula with the help of example so that i can understand this properly, i will be very grateful to you for helping this.
with regards
sehdev singh
Register to Reply 4 comments
harry potter (1); sehdev singh (2); TonyS (1)
