Previous in Forum: Voltage Controlled Oscillator   Next in Forum: VGA Connector for HP Proliant G6 Series Server
Electronics
07/05/2012 10:15 AM
can we find resistance without using colorcode, multimeter,ohmmeter ????
Re: electronics
07/05/2012 10:21 AM
Yes.
Re: Electronics
07/05/2012 1:53 PM
Can I use a baseball bat?
A fellow once used a baseball bat to measure my resistance...
Re: Electronics
07/05/2012 3:10 PM
Some resistors are marked with the resistance in ohms.
Alternative methods can include the use of an oscilloscope (if the resistor is part of a powered circuit, or loudly yelling "RESISTANCE IS FUTILE" if asked what the resistance is by the boss.
Good Answers: 73
Re: Electronics
07/06/2012 11:59 AM
If you are very lucky, you might be able to pick it from a schematic.
You might approximate it using temperature if you know how much power it is dissipating. For the power you will need to know voltage and current. But that requires a multimeter.
There are many types of indicators on the market. What are you willing to use?
Re: Electronics
07/06/2012 12:18 PM
I suspect his exam paper was looking for Wheatstone Bridge.
I offer this now because if it is a homework/test question it is too late.
Australia - Member - Igor...pull the switch!!!
Good Answers: 12
Re: Electronics
07/07/2012 10:03 PM
...what more can I say...
CraziestOzzy
Register to Reply 6 comments
CraziestOzzy (1); Doorman (2); jack of all trades (1); lyn (1); NotUrOrdinaryJoe (1)
