Previous in Forum: Technical Specification of Optical Fibre.   Next in Forum: Generator Load Sharing System
11 comments
Sizing a Generator
07/06/2012 5:58 AM
What will be the standard size of a generator for a 100 kva single phase step-down transformer supply. Is a 125KVA gen-set enough size to this kind of load in a hospital building? Pls. comment.
Pathfinder Tags: Generator Sizing
Re: Sizing a Generator
07/06/2012 7:05 AM
put it this way... how much does cost a 125 KVA gen, and how much does it cost a 200KVA gen... if you had to pay 1k more for the second I would recommend having the second. and then perhaps you could feed 2 steppers
“For no man can forbid the spark nor tell whence it may come.” ? Francis Bacon
07/06/2012 8:29 PM
Thank you sir, You are correct the price diffrence is minimal as we go higher in KVA ratings for Gen-set. Is the fuel consumption of a bigger gen-set varied much? Anyway we only load the gen-set maybe at most 5-6 times a year. we warm-uped the engine once a week for 10 minutes!!
07/06/2012 7:09 AM
IF YOU CONSIDER 25% MARGIN THEN IT IS CORRECT .YOU SHOULD GO FOR SINGLE PHASE DIESEL GENRATOR.
BUT WHAT IS THE VOLTAGE OF TRANSFORMER PRI/SEC.?
07/06/2012 8:15 PM
Sir, in the Philippines our utilities supply 13.2KV in Primary / 220V secondary. Thank you for your advise. Godbless and more power to you.
Good Answers: 102
07/06/2012 11:53 PM
125kVA single phase?
Not likely.
07/07/2012 6:49 AM
Yes Sir, this is a single-phase 220V 125KVA transformer, the supplier need to reconnect the generator windings in order to deliver a single phasesupply at 220V, wherein it is clear that our required max. full load current is attained at full load.
07/10/2012 9:51 AM
Hello luv123 ;) yes, I did forgett to mention the margins! cheer´s again!
07/06/2012 12:58 PM
07/08/2012 11:04 AM
Can u tell us why are you using a single phase 100kva? what is the type of Load?
07/09/2012 7:27 AM
We are using this generator for a single-phase 220V school building load with night school sked till 10 a.m.
07/11/2012 3:04 AM
To select a suitable generator load details is essential...
Register to Reply 11 comments
electronick (2); luv123 (1); lyn (1); nesubra (2); siegfredo c. tabanag (4); Wal (1)
