Previous in Forum: Condensate Pot   Next in Forum: Instrument System Block Diagram
8 comments
Confusing Uses of the Word "Backpressure"
07/07/2012 11:12 PM
Hi All,
It appears, as seen in this article, that the use of the word "backpressure" refers to pressure downstream of the reference (e.g. orifice, valve, manifold). However, in the term "backpressure control valve" as seen here, it is used to refer to the pressure upstream of the reference.
Does anyone have any opinion on this or had instances where it created confusion?
Cheers.
Pathfinder Tags: backpressure
Re: Confusing Uses of the Word "Backpressure".
07/07/2012 11:35 PM
I too have seen the term used either way, more often for upstream pressure. The context has ordinarily made it clear, but I can see how it might be confusing in some cases. The terms "upstream pressure regulator" and "downstream pressure regulator" seem more precise.
07/08/2012 6:49 AM
I think you're mis-interpreting the Wikipedia article - it is referring to the increase in pressure upstream of the exhaust pipework - i.e. at the engine exhaust port, just as the second reference describes the pressure upstream of the valve.
07/08/2012 6:53 AM
Your confusion lies in your use of the word "reference" when attempting to define "back pressure" in the two contexts above.
Back pressure is back pressure, regardless of the point of reference.
07/08/2012 8:17 AM
"Back pressure is back pressure, regardless of the point of reference."
Very true. Ex Mrs. Doorman was never confused about the point of reference whenever my backpressure became evident.
I tried to blame the dog but that never worked very well.
07/08/2012 10:45 PM
bean-o there.
done-o-that.
Good Answers: 59
07/08/2012 11:14 PM
I have yet to get confused. The situation sets it in the right frame, normally.
Good Answers: 102
07/09/2012 12:56 AM
That valve you put up as an example is for regulating the backpressure, where backpressure is the discharge pressure, of what ever it is fed from.
The literature says the valve works by controlling the inlet pressure of the valve and the inlet of the valve is fed from the discharge of whatever is pumping. ie the valve's inlet pressure is controlled to control the discharge pressure of what ever it is appended to.
That first paragraph in the literature is pretty clear I think and then gives an example too.....
07/09/2012 1:57 AM
Thanks to everyone who has contributed. The combination of your comments helped clear the confusion.
Cheers.
Register to Reply 8 comments
Doorman (1); JohnDG (1); leveles (1); lyn (2); seg (1); Tornado (1); Wal (1)
