We are going to upgrade the Power facility. Your Valuable
suggestions are to be required
System Description:
1. Grid -A (Main
Grid): Supply 132 KV to Grid -B through
Over head Power Line
2. Grid-B: Step
Down 132 KV to 11 KV. This Step down Station has a 26/20 MVA, 132/11 KV
Transformer
3. Factory: Takes
11 KV from Grid-B
4. Power Plant: A
Power plant having a Capacity of 25 MW
is going to be installed to feed Power to the Factory & to add remaining Power to
the Main Grid (In order to sell the Power) Grid-A.
This Power Plant will be Connected with Grid-B, so that the Factory utilizes
the Power (as required) of the Power Plant
and remaining Power would be added to the Grid-A .
Note: Power Plant,
Factory and Grid-B are Co-located with each other while Grid -A is 32 km away
from them.
Factory has Power consumption of 17 MW for 16 Hours and
then Power demand decreases to 6 MW for the remaining 8 Hours.
Which Configuration would be the most Suitable/flexible/Cost
effective to Connect Power plant to Grid-B?
1. Connect the Power
Plant with the Grid-B through 11
KV Line (Power Plant should generate 11 KV)?
2. Connect the Power
132 KV independent Line (Step up the Power generated to 132 KV)?
If we use 132 KV Line
configuration then is there any need of Separate
overhead Line (From Grid -B to Grid -A)to send the power (8 MW for 16 Hours
and 19MW for 8 Hours) from Power Plant to
main Grid-A through Grid-B? What would be the additional equipments
required Like Transformer etc
Thanks & Kind Regards
Aghvel Niazi
