Previous in Forum: Ball Bearing Swivels/Marine Use   Next in Forum: Worm Shaft Acceptable Backlash
Impact Testing Requirements
07/14/2012 11:09 PM
Hi Everyone,
I have a question regarding impact testing requirement in Fig. 323. 2.2b of ASME B31.3.
I do not exactly understand about minimum pipe wall thickeness mentioned in General Notes: (a).
Specifically speaking, to calculate the minimum pipe wall thickness I wonder if both mill tolerance and allowances are substracted from nominal pipe wall thickness or allowances only.
I would really appreciate replying from any of you experienced.
Thanks
Re: Impact Testing Requirements
07/16/2012 2:59 AM
I think the minimum wall thickness is equal to the nominal wall thickness minus tolerance. Allowance may include corrosion allowance.
07/16/2012 1:55 PM
That would be called stacking tolerances, that is not allowed.
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
Register to Reply 2 comments
