Gents,
I have problem with Single Phase Pump 2.2KW using for lifting & Transfer water purpose last month about 05No Pump burned out its running coil all similar case am using Generator Supply no variation found in voltage its constant but control LBS with contactor what will be the reason this continues happens should I use Over load relay to protect???/
Please advise friends..
