Previous in Forum: Butterfly valves verses ball valves   Next in Forum: Water Pump Identification
Calculating Torque: Rotating Axle in a Circular Housing
05/15/2007 5:19 AM
How do I calculate torque? I have a rotating axle in a circulare housing, and the axle is rotating. The housing is oil filled and pressurised. What is the torque on the housing?
Re: CALCULATING TORQUE
05/15/2007 6:18 AM
can you illustrate your assembly?
generally speak touque is related to rotation speed.
we can write as
M= J * dw/dt + Mr(resistance torque)
South Africa - Member - ShoSholoza Engineering Fields - Mechanical Engineering - New Member Popular Science - Weaponology - New Member
05/15/2007 6:39 AM
An illustraion would help immensely, especially to show what is on the endpoints.
Are you referring to the torque on the shaft or housing?
If it the housing, then this would be due to the viscosity of the oil between the shaft & housing? In this regard the torque could be calculated [Formula: me don't know right now], however if it is of small scale then directly measuring the torque would be more accurate: measure the force needed to stop the rotation at distance x then torque = Force*x. The torque value would be a peak soon after start up [cold oil, max viscosity] and decrease as the oil heats up.
Can you imitate yourself?
Re: Calculating Torque: Rotating Axle in a Circular Housing
05/16/2007 7:47 AM
Wouldn't load have some influence also?
05/16/2007 2:46 PM
Show us more illustration, is it something like MRI that hospital use to diagnose brain tumor with x-ray device is mounting inside was created torque sort of speak? vibration?
Torque:F*lenght
Hollow cyclinder(inertia)=1/2*mass(Rinside^2+R outside^2)
and depend on the counter balance of the mass attached. Principle the torque formula in above.
Nuphea
Register to Reply 4 comments
Anonymous Poster (1); cnpower (1); nuphea (1); The Hammer (1)
