Previous in Forum: Design Shell Tube Software   Next in Forum: Control Specialist
NCMR Database
07/19/2012 6:47 PM
I am looking for software to manage and store Nonconforming Materials records.
Re: NCMR Database
07/19/2012 7:10 PM
Have you searched anywhere for data management software?
Re: NCMR Database
07/20/2012 2:45 PM
Nothing off the shelf is adequate. Didn't want to build one from scratch if we didn't have to.
Good Answers: 104
Re: NCMR Database
07/19/2012 10:03 PM
Depending on how tightly integrated your requisitioning, purchasing, planning, work flow, etc software is, it would seem that your best bet would be either 1. Use software from that vendor, or one of those vendors, or 2. Write your own, or hire a developer to write it. At first blush, this doesn't seem too formidable; however, I realize that whoever does the work has to understand how the pieces all fit together, and gaining that understanding can be harder than creating the new application.
If you can tell what other software you are using, someone else might be more helpful.
Re: NCMR Database
07/20/2012 2:56 PM
Thank you for your response. Guess we will have to build one from scratch. What we have now is getting too big for Access.
Good Answers: 104
Re: NCMR Database
07/20/2012 3:02 PM
You must have a bunch of NCM .
Re: NCMR Database
07/23/2012 8:45 AM
Then this information needs to be available to the developer in order to develop a system that will cope.
If there are that many NCRs then there is a management problem at the facility.
Re: NCMR Database
07/24/2012 10:33 AM
This database is also tied into incoming inspection and product travelers. We are now considering a network based program with a web interface. Probably won't find anything off the shelf that is even close to what we need.
Register to Reply 7 comments
bigg (2); lyn (1); Mark Murray (3); PWSlack (1)
