Previous in Forum: Three Phase Current Calculation   Next in Forum: Current Inductor Motor Relationships
Voltage Calculation of Step up Transformer
07/20/2012 1:26 AM
suppose in a 3 phase step up transformer if we have shorted u1, u2 & gave 415 supply to between v1 & w1 what will be voltage between u2-v2, v2-w2 & u2-w2
Re: Voltage calculation of step up transformer
07/20/2012 3:20 AM
If the transformer's circuit protection equipment is correctly installed and working, zero in each case.
Re: Voltage Calculation of Step up Transformer
07/20/2012 4:11 PM
PW
Would you translate the u's, v's and w's to English, as in primary and secondary terminals, if that is what they are.
Thanks
07/21/2012 5:51 AM
Without any information on the connection type or schematic, then unknown.
07/21/2012 12:32 PM
What is the transformer stepping up to? What is the target? Why would you want to do this?
In normal use, connecting u1 & u2 will have no effect on the phase to phase output volts if the secondary is otherwise isolated. Relative to the primary neutral it will have 240vac added vectorially.
Connecting 415vac between two phases of the primary will induce something in the secondary windings defined by the way the flux devides in the three (or five) limbs. So the volts you ask for cannot be calculated without a lot more information.
Sounds like an exam question posed by an academic with no experience of the practical world.
Good Answers: 170
07/29/2012 9:37 AM
What is the vector group of the trf?
Anonymous Poster (1); electricalexpert65 (1); engineertony (1); LAA_Lucke (1); PWSlack (1)
