Previous in Forum: When Synchronous Motor is used Over Induction type Motor   Next in Forum: Axens IN 042 Standard
Datum Reference in Drawings
07/20/2012 2:31 AM
Can any one expln what is primary , secondary and tertiary datums and their relation with 321 locating principle ?
Re: Datum reference in Drawings
07/20/2012 3:35 AM
Re: Datum Reference in Drawings
07/20/2012 1:19 PM
Primary datum controls 3 degrees of freedom; the translation along the Z axis, rotation about the x axis, and rotation about the y axis. Secondary datum controls 2 degrees of freedom; translation along the y axis and rotation about the z axis. The tertiary datum controls 1 degree of freedom, translation along the x axis.
Good Answers: 102
07/21/2012 12:32 AM
United States - Member - US Navy Veteran
Location: Nothing sucks more than that moment during an argument when you realize you're wrong.
Good Answers: 22
07/21/2012 10:41 PM
Primary = 3 points of reference or (Level)
Secondary = 2 points of reference or (Align)
Tertiary = 1 point of reference or (Origin)
A "3,2,1" alignment achieves Level, Align, Origin (which establishes X0,Y0,Z0)
Think of a 3,2,1 alignment as establishing home plate location at the baseball field. Your going to report/design the location of the other bases, dugouts etc.... from that primary location. If I need to know where first base is from home plate (X0,Y0,Z0) then you would give me coordinates from (relative to) home plate.
The objective is to lock - or - establish X zero, Y zero, Z zero.
** Usually but not always defined as:
X = side to side movement
Y = front to back movement
Z = up and down movement
Example: Lay a framing square on a work bench and place a block of wood or metal in the corner. You have just created a "nest" that with a clamp isolates 6 degrees of freedom. x,y,z, - pitch, yaw, roll about these 3 axis.
You never know when it will strike, but there comes a moment when you know that you just aren't going to do anything productive for the rest of the day.
Register to Reply 4 comments
Anonymous Poster (1); Doorman (1); markar (1); Wal (1)
