Greetings CR4 Contributors.
I have a problem with an Elgo P8822 Controller.
The problem is that when the controller is set to single mode, the axis's move to their positions, but don't come to rest at the actual desired position, they could be 1 or 2 numeric points out, Not Much but a lot to my customer.
I am sure that this is a just a programme fault, also I have asker the customer to clean an lube the drive train in case that is causing the fault.
Can anyone in the CR4 community help me with this problem.
Best Regards
Joe
