Previous in Forum: Model OHL Failure Statistics   Next in Forum: TNS System
16 comments
Bi-Voltage Induction Motor
07/22/2012 12:56 PM
Hi everybody, please can you help?
I recently inherited a Ferrari 16" scroll saw which has a bi-volt induction motor presently running on 220v. The previous owner used it with a step up transformer, 110 - 220 volt as our domestic voltage here in Brasil is 110v.
I believe it should be able to run on 110v by changing the wiring into the motor, but not 100% sure so decided to confirm with the experts out there.
The motor has four wires connected to it, two red which go to a 4 micro-farad capacitor, a blue which is connected directly from the supply & the brown which is switched.
Anyone any ideas? I have'nt as yet done any winding resistance measurements etc., but could do if necessary.
Bill
Re: Bi-Voltage induction motor.
07/22/2012 2:58 PM
What's a bi-volt motor? or do you mean dual-voltage?
07/22/2012 7:06 PM
Bi-voltage/dual voltage, the blurb I could find on the internet mostly called it the former.
Good Answers: 104
07/22/2012 3:35 PM
If the wires are as you describe, that is not a dual-voltage motor.
07/22/2012 7:01 PM
Thanks for that. This was my own thinking also but wondered if taking the capacitor out of circuit......???
Reply Score 1 for Off Topic
07/22/2012 4:45 PM
Throw the motor out, Boss, and fit one of the same power rating that runs on your local voltage. I wouldn't like to be in the area if you plug it in and it's wrong.
Good moaning!
07/22/2012 7:03 PM
Thanks for that. I already tested it on 110v & it just buzzed unhappily!
Good Answers: 804
Re: Bi-Voltage Induction Motor
07/22/2012 8:12 PM
Bi-Voltage usually means tow TPYES of voltage, as in AC/DC... Dual Voltage means two different LEVELS of voltage.
If it says "Bi-Voltage" on the nameplate but only lists one voltage, it's likely what we here in the US call a "Universal" motor, it can take 220VAC or 220VDC, it works the same either way. That is what is commonly used in small HP portable power tools.
The big clue is, does it have brushes? A Universal motor has brushes. If you are not sure, look at the end housings when it is running in the dark and if you see little blue sparks, those are from the brushes and it is an AC/DC Universal motor. But they are never dual voltage as far as I know.
07/22/2012 8:25 PM
JReaf, thanks for your post. It's an brushless induction motor & the name plate definitely says 110/220v 60Hz which means it is A.C.
PS I loved Michael Palin & the Monty Python sketches also!
Good Answers: 104
07/22/2012 8:33 PM
Wait a minute. If you have the nameplate and it says 110/220 it is dual voltage. There should be a wiring diagram showing how to reconnect the leads, or possibly a small switch somewhere on the motor or the additional wires are tucked out of sight. Maybe there is another connection box somewhere on the motor? (I'm pretty sure if you take the capacitor out of the circuit, you are going to let the smoke out.)
07/24/2012 11:41 PM
very useful to learn about bi-voltage
tks.
alex
azero industrial limited
07/22/2012 11:40 PM
hi bill,
you can login the site of manufacturer check its' details here.
hope it is useful for you.
regards,
alex
07/23/2012 4:10 AM
There was a reason the previous owner used an inverter so why not do the same, get a 110-230v inverter or change the motor.
Bazzer
07/23/2012 4:35 AM
Hi
In the movies it is always the Red Or Blue Wire that should be cut!
I don't think that by changing the electrical connections that this would be an easy fix, you would have to study the windings to sort this out
Cheers,
Joe
07/23/2012 8:40 AM
As others have stated, along with what I would do is:
Look at the nameplate. It should give a wiring diagram from 110 vac to 220 vac.
Check the model number and call the manufacturer for information
Lastly, go online and search for the manufacturer and model number for technical information.
07/23/2012 2:18 PM
Thanks to you all for posting. I have a inverter/transformer that I've been using, but as the motor plate says 220/110 volts, I was wanting to try using it directly from mains (110v).
The motor is on a 16" scroll saw, made by Ferrari - possibly here in Brasil but I think more likely China & rebranded here - but nothing so far on their web site, will keep looking. Strangely enough, the safety labeling on the tool is in English rather than Portuguese.
No information about motor manufacturer other than Type YYL5614, 120w induction motor. Googling that got me nowhere unfortunately but will keep trying.
07/23/2012 6:39 PM
...and if the diagram isn't on the label, it could be on the underside of the wire junction cover...
Clintb3252
Reply to Forum Thread 16 comments
Anonymous Poster (2); azerolimited (2); Barnicle Bill (3); Bazzer Englander (1); bigg (2); Clintb32 (1); Crabtree (1); Joe Sparky (1); JRaef (1); Munster (1); SolarEagle (1)
