Previous in Forum: Pipe Support   Next in Forum: Max. Allowable Stress for SA-516, Gr.70
Rifled Tube
07/22/2012 10:41 PM
HI ALL,
ANYBODY CAN TELL ME ABOUT RIFLED TUBE?
IS IT EFFIECENT IN CASE OF USE IT IN BOILER TUBE TO OVERCOME SCALES EXISTING IN WATER?
REGARDS
Pathfinder Tags: thank you for your time
Re: RIFLED TUBE
07/22/2012 10:43 PM
ARE YOU TAKING A TEST?
Re: Rifled Tube
07/23/2012 1:39 AM
Please turn off the all-caps.
Rifled (enhanced) tubes make sense in contact with clean fluids of lower heat conductivity, such as air, oil, etc. I'm surprised to hear of their use in boilers, because they could be fouled by scale on the water side or soot on the fire side.
Good Answers: 445
Re: Rifled Tube
07/23/2012 2:37 PM
Internally rifled tubing is used in modern boilers to increase the heat transfer rate in certain sections. Fouling is less of a concern since the water condition is very tightly controlled.
See page 12 & 17 in this paper:
http://www.fwc.com/publications/tech_papers/files/TP_PC_07_01.pdf
For those of us who have never been inside a generating station reading the entire article will also give an excellent introduction onto the non-trivial amount of engineering and material selection that goes into modern power boiler design.
Register to Reply 3 comments
lyn (1); RAMConsult (1); Tornado (1)
