Previous in Forum: Generator Field Circuit Breaker Fault   Next in Forum: How to Couple PL Carrier Across Two Phase Power
Development of Permanent Magnet Rotor of 2 kW Three Phase Motor
08/02/2012 2:46 AM
We have number of three phase 0.33 kw to 2 kw permanent magnet motors working last seven years. We are having defective permanent magnet rotors wish to develop permanent magnet rotors for the motor having specification below
TYBZ-200-100L-6
0.33 KW TO 2 KW
67 V TO 380 V AC
3 PHASE
340 TO 1940 RPM
17 TO 97 HZ
We wish to know construction details with material specification of the above motor-rotor
Regards
Sadasivam
India - Member - Proud to be INDIAN Engineering Fields - Power Engineering - New Member
Re: Development of Permanent Magnet Rotor of 2 kW Three Phase Motor
08/03/2012 5:51 AM
You have already developed PM rotors which are working for 7 years. Now what are the defects that you have found???
you need to go, to get something
08/04/2012 12:46 AM
Dear Sir
These permanent magnet is aluminum die cast rotor and found the shape has deformed.Suspect that ferro magnet used inside these aluminum die cast rotor has weakened.Performance of these rotors are very poor. Photo enclosed of servicable rotor.Stators are OK.We wanted to develop this rotor
Regards
Sadasivam
08/04/2012 4:44 AM
Dear Sadasivam,
I can suggest to use surface mounted permanent magnet rotor in which the magnets are sticked on rotor surface by using LOCTITE 334 magnet bond and you should use rotor steel which is having high permeability. These type of rotors will perform well and no mechanical problems. But i am not sure what is the result at higher speeds (>600 RPM)
Register to Reply 3 comments
