Previous in Forum: Requisition of Vibration Related Sttandard   Next in Forum: Turbine Generator
9 comments
Welding and Piping
08/06/2012 10:32 PM
In our project weld toe to toe distance is min 4 times of nominal pipe wall... At the same time in piping PUB piece distance should min 150mm... What is different between this???? Can any one explain???
Re: Welding and Piping
08/06/2012 10:36 PM
Where are you?
Do you have specifications?
Etc. etc. etc...................
08/06/2012 11:21 PM
Which specification u want??????
08/06/2012 11:32 PM
The ones which control the welding processes used on the project.
Never mind, I hear my mom calling.
Bye.
08/06/2012 10:48 PM
The 4 x nominal wall makes sense, but I suspect the 150 mm minimum "pup" is only informal.
08/06/2012 10:57 PM
Can tell me in which code they mention 4x nominal wall thickness...
08/06/2012 11:42 PM
I don't know; you are the one who first mentioned this, so perhaps you should tell us where it came from.
08/07/2012 12:24 AM
This one mention in our client requirements...
08/07/2012 12:30 AM
What we have here is, failure to communicate.
Good Answers: 61
08/07/2012 9:02 AM
None of the Piping Codes (ASME B31.1, B31.3, B31.4, B31.8) address this.
Do it once and do it right
Register to Reply 9 comments
dineshjdk (3); lyn (3); PennPiper (1); Tornado (2)
