Previous in Forum: Using an EPDM Rubber Liner Valve With Chemicals?   Next in Forum: Gravitons
Sour Service Application
05/16/2007 9:26 AM
Sour Service Application For Flange and Fitting:
Chemical properties restrictions of different grades like
ASTM A105, ASTM A /ASME SA 182 F 316,316L, 304,304L,321
Etc.
Is, the following test are sufficient for 'SOUR SERVICE'
Applications?
1) chemical , tensile , microstruchture , hardness , pitting
corrosion test as per G48 method B , or ASTM A921 method C.
2) Hydrogen Induced Cracking (HIS) as per NACE 02 84.
3) Sulfied Stress Corrosion Cracking (SSCC) as per
NACE 0177 at test temperature 24 Deg.
Re: Sour Service Application
05/17/2007 11:36 AM
I'm sorry but I'm Curious as to what "Sour Service" is. Do you mean "Sewer Service" meaning disposal of waste service?
05/17/2007 11:59 AM
HI,
IETECH,
I MEAN SOUR IS ' SPECFIC OXIGEN UPTAKE RATE' NACE STANDERED.
THANKS.
Good Answers: 204
05/24/2007 3:28 PM
Sour service refers to the oil and gas industry, and applications that have to deal with "Sour Gas" coming out of the ground.
05/25/2007 3:59 AM
Sour service basically means that you have a fluid with a certain amount of H2S, in terms of partial pressure, and you have water.
The Sour Service requirements for materials selection and testing are contained in the NACE MR 0175 / ISO 15156 1-3 for Oil & Gas , Upstream facilities and NACE MR 103 for refireries and chemical plants.
In these statndard you'll find all the information regarding the test and requirements for materials.
Hope this help
regards
Vitt
Register to Reply 4 comments
chrisg288 (1); strider6 (1); user-deleted-5 (1); vidyadhar deodhar (1)
