Previous in Forum: Advantage on Single Busbar Design   Next in Forum: Need Information for AC Motor.
CT Flux Problem
08/08/2012 3:24 AM
1000/1A CT current injected through loading transformer. CT secondary shorted with short loop cable. measuring with clamp meter, the value varies with position of clamp meter. when put long loop in secondary the ratio proper unless the position varies.
Re: CT flux problem
08/08/2012 3:33 AM
And?
Re: CT flux problem
08/08/2012 3:52 AM
short loop why the values varies.... may be CT flux affect clamp meter reading... CT is a ring type one.... Putting multimeter in secondary with short loop the ratio is proper....
Re: CT flux problem
08/08/2012 3:57 AM
GA
Register to Reply 3 comments
