Previous in Forum: Difference between synchronous and induction motor   Next in Forum: HDE
10 comments
Charging Batteries
05/16/2007 10:53 AM
Hi all, I need help.
I want to charge a battery 12V 2Ah Nickel Cadium in 2-3 hours because my clients are complaining from charging the battery in more than 8 hours. I tried to change parts in the charging circuit but it is useless. Please it is urgent. If anyone has solution kindly send it and it will be appreciated..
Good Answers: 40
Re: Charging Batteries
05/16/2007 11:33 AM
What is the application? .....Tools? computer? solar power? automotive?
Tool:
http://www.amazon.com/DEWALT-DW9109-Vehicle-Charger-7-2-Volt/dp/B00004RHJU
warning if the batteries were not built to handle the higher current of fast charging, the batteries may destroy themselves.... heat, fire, possible explosion
05/16/2007 9:06 PM
...which might cause bigger complaints from the client...
05/17/2007 4:41 AM
The application is a security equipment. it is called security mirror used to search for bombs under vehicles before they enter any parking.
it consists of a mirror,2 fluorescent lamps and a sensor. we use a 12V 2 Ah Nickel Cadium Battery.
thanks for your cooperation.
Good Answers: 40
05/17/2007 9:54 AM
The Makita brand power tools use the 12v 2AH batteries. They have a charger that recharges in 45 min.
I could not find any schematics
05/17/2007 5:34 AM
The units should be designed to allow rapid battery replacement, sell the customer more batteries, retain the slow charger as it will extend total battery life as long as it is using a modern charging sequence that really looks after the battery!!
Such customers are the first to complain if the batteries need completely replacing after a relatively short time!! Such batteries should last some years (or until the guarantee has run out!)
There are enough special charging control chips around that can be used to safely charge such batteries.....
Maybe NICAD is not the best for your application.......but too late to worry now.....but make sure that you do not warm up the battery when charging, that drives off the water in the battery and the eventually battery dies......
05/17/2007 10:34 AM
Contact the battery manufacturer. Ask for a technical representative. Explain your problem to him/her and see if there is some charging rate which may shorten battery life somewhat but allow for reduced charging times. Often charge rates are selected to maximize battery life and in this case perhaps some battery life can be sacrificed for customer satisfaction.
intellectuals solve problems, geniuses prevent them ~ Einstein
05/17/2007 11:44 AM
Its more complicated then you think. A slow 8hr charger is a very simple low current power source. A fast charger need to be able to detect when the battery is fully charged and shut itself off or switch itself into low current charging mode.
Contact your battery manufacturer and ask what is the highest charging current the battery can take. You'll then need to find/design a new charger for the application. One source of highend battery charger is your RC (remote control) store. You can buy 2-30 cell 15A fully programmable charger for a few hundred dollars. They can discharge the battery first to remove memory effect.
You learn a lot when you have a hobby.
Pineapple
Good Answers: 120
05/17/2007 3:28 PM
change the flourescents to LED lamps of same lumens out = 3 times the battery life.
Add push button switch for the LED lights (which are instant one) = twice more bettery life.
You want 20 leds to play with, I will send you 20 and you can make a prototype. send PM
Add a small color cam and monitor to add operator safety
Per Ardua Ad Astra
05/17/2007 4:45 PM
It is not an open lead-acid that can be Flash-charged.
All new types of batteries need special care in charging & discharging.
Ni-Cd Li-M etc are very efficient but very delicate to damage if not properly handled.
You are talking about the modification to charger.
can you post a readable circuit diagram of it?
05/19/2007 4:22 AM
Dear Omar Sheta,
The quickest route to a solution for your problem, in my view, is to purchase a Mascot 2415 charger. It uses the -deltaV technique and charges packs containing ten cells with a current of 3.5A.
Kind regards,
Jos
Register to Reply 10 comments
Andy Germany (1); Anonymous Poster (2); aurizon (1); Haajee (1); joslenssen (1); Omar Sheta (1); taejonkwando (1); techno (2)
You might be interested in: Nickel and Nickel Alloys, Battery Holders
