Previous in Forum: Another Way?   Next in Forum: Harder Than Anything!?
3 Phase Generator
08/11/2012 3:22 AM
i have a 3 phase diesel generator of 8.75 kva( 7kw) power rating.
it is use for running 3 phase motor but my sir force me to run single phase load with this generator. but he is not clearly mention about single phase load. he is telling that load may be very. specially upto 7000 watt. so i want to know that is it possible to run single phase and 3 phase load with same generator (3 ph). if yes then how? any suitable option with circuit diagram. plz help me i m in a big trouble.
thank you
regards
abhishek tripathi
Good Answers: 125
Re: its my imp assignment plz help me
08/11/2012 10:49 AM
Yes, your imp help must come from your sir.
Re: 3 Phase Generator
08/13/2012 9:46 AM
depends on how many wire you hook up.
09/28/2012 9:51 PM
I would suggest starting with a standard large frame automitive alternator or generator with it's own regulation. Pretty simple compared to converting to permanent magnet and having a separate charge controller. Also available in standard voltages (12, 24, 32)
Convert windmill speed to alternator speed with a toothed belt or standard serpentine automotive if you want.
09/05/2013 11:27 AM
The generators are able to run 1/10 hp of its capacity due to the more starting current.if your generatorhave 8.7kw it is able to run o motor of 1/8.7kw. Thx
05/23/2020 7:07 AM
I know what you mean
Reply Score 1 for Off Topic
129CBRider (1); dieudonne (1); jmmyadam (1); lyn (1); susanie (1); WJMFIRE (1)
