Previous in Forum: Cut or Drill?   Next in Forum: Engineering Reference Tools
Combine Use of NVR & Back Pressure Valve
08/13/2012 11:24 AM
discharge of my metering pump (diaphragm type) have a nrv. and company has given a back pressure valve to. then can i use back pressure valve also in discharge line? if so, then how?
Pathfinder Tags: metering pump discharge
Good Answers: 137
Re: Combine Use of NVR & Back Pressure Valve
08/13/2012 6:15 PM
That's where you would put the back pressure valve. It's there to provide a positive pressure to pump against, without it metering may not be accurate. Eg in an extreme case, where the supply tank is at higher level than the dosing point, without a back pressure valve liquid can flow even if the pump is not running.
You might also need a pressure relief valve, unless the pump has another way of preventing overpressure. Pressure relief valve can be same type of valve as back pressure valve (but set to a higher pressure). Difference is it's installed on a branch from the pump discharge line, and relieves to atmosphere, or to the supply tank, or at a pinch to the pump suction pipe.
08/14/2012 11:02 AM
thanks codemaster.
Register to Reply 2 comments
