Previous in Forum: Compressor Capacity   Next in Forum: Combine Use of NVR & Back Pressure Valve
Cut or Drill?
08/13/2012 10:40 AM
Hi, I am trying to fabricate a 304 stainless steel fire tube heat exchanger as sketched. My concern is, can I cut all the holes on both tube walls with plasma cutter or should I drill them? Does plasma cutting have any bad effect on the 304? Since the heat exchanger will be under thermal stress, will plasma cutting weaken the welding area or cause metal fatigue? All suggestions, comments and advice are most welcome. Thank you. Yip
Re: Cut or drill?
08/13/2012 10:45 AM
Discuss the matter with the Engineer/Surveyor from the company that is to provide burst indemnity insurance cover on the equipment, as it looks like a fire tube boiler, and there is a lot more to making a boiler than merely drilling a few holes in a tubeplate.
  • Is that sketch all there is, or is there a detailed mechanical drawing?
  • Process fluid, its temperature and pressure?
  • Where is the stress analysis calculation, showing the location, diameter and number of the stays?
  • What is the intended rating of this equipment?
  • Installation location?
  • Etc.
Re: Cut or drill?
08/13/2012 10:50 AM
warpage, looser tolerance
Drilling would be more accurate. with tighter tolerances.
back to the principal. this is dangerous.
  • What do you plan on accomplishing here?
  • I do not see any safety devices such as pressure relief,
  • What is your goal of temperature and pressure requirements,
  • being a fire tube, what is your fire box contructed out of?
  • what are you tubes made out of?
  • How are you going to deal with thermal expansion of the tubes?
  • What type and spec. of tube are you going to use?
  • What Material of tube or you going to use?
  • some dimensions would also help?
to start with.
Good Answers: 58
Re: Cut or Drill?
08/13/2012 5:18 PM
Yup, you need to learn about boilers. Google boiler explosions, images. One this size will take out the average house.
You need a degree and a license to build and fire up a boiler. Otherwise, insurance will not pay damages, including death benefits. No joke.
On topic, to make the cleanest holes, see if an electrician's chassis punch/hole punch will make a hole the size of your tube, or get tubes to fit the holes those punches will make, they get quite large. Perfect circles, clean cut, easy to do once you get the proper equipment.
mike k
Good Answers: 58
Re: Cut or Drill?
08/17/2012 1:28 PM
As a follow-up to this project, the hole punches can be rented, with a nice hydraulic cylinder and pump to do the hard work.
mike k
Re: Cut or Drill?
08/14/2012 6:52 AM
The heat exchanger is actually located in a square open top tank for heating water to 60 deg C. The volume of water to be heated will be around 1000 Liter. Level sensor and temperature sensor will also be installed. All the parts will be of 304 s/s.
Re: Cut or Drill?
08/14/2012 10:20 AM
The original sketch, and the post it is in, do not state this.
Good Answers: 19
Re: Cut or Drill?
08/17/2012 1:00 AM
It is still a Boiler > Hot water Boiler.
Register to Reply 7 comments
ducon (1); mike k (2); phoenix911 (1); PWSlack (2); unns_boy (1)
