I forgot my password.
Don't have an account?
what is the usage of ASTM A283 grade A in tank fabrication?could we use it instead of A283 grade C?
What code is the tank being built to and what does that code say?
Hint question: How do the minimum yield and minimum tensile strengths of the 2 materials compare?
thank you for your reply dear bigg.
the code is API 650.
A283-C : min yield= 380 MPa min tensile= 205
A283-A: min yield= 310 MPa min tensile= 165
the tank is atmospheric type.
how could I calculate the safety value of yield and tensile strength?
Are you the designer or the fabricator?
If you are the designer, carry out the design calculations using the allowable stresses for the material (Grade A) you intend to specify.
If you are the fabricator, NO you cannot substitute material unless specifically allowed by the code. That's what specifications and codes are for.
thank you very much Bigg.
I am a fabricator.
