Previous in Forum: Plate Defects   Next in Forum: Dwell Time
9 comments
Can I Use Silicon Carbide Abrasive Belts?
08/15/2012 10:41 PM
Can i use silicon carbide abrasive belt to polish 13Chromium pipe?. because the pipe mtl is sensitive to metals. normally we use only aluminium zirconia not even we use al. oxide.
Re: Can i use silican carbide abrasive belts?
08/15/2012 11:16 PM
Has there been any heat treatments? What is your intended purpose in polishing? Is this for a drill point?
08/15/2012 11:21 PM
heat treatment is not on the polishing area. we need to remove mill scale and rust particles on the pipe to make wire screen on the pipe. sometimes we do driiling on the polished area.
08/16/2012 12:04 AM
I would use the softest media that would work....here is a list
http://www.kramerindustriesonline.com/blasting-media.htm
08/16/2012 12:54 AM
actually i cant use a softer media, currently we are using P24 grit. but we are using 2 belts per pipe. polishing area it self nearly 30+ foot. pipe dia from 3-7". i want to reduce the no of belts used and improve the finishing. current finishing also not so good.
08/16/2012 1:03 AM
08/16/2012 1:10 AM
actually there is no possiblity of using blasting. we already have polishinf machine. i am looking only for changing the belt mtl.
08/16/2012 1:16 AM
Well then I don't see why not....
08/16/2012 1:20 AM
sorry dont understand...
08/16/2012 4:34 AM
When all the other possibilities have been eliminated, the proposed action is the only one left.
Register to Reply 9 comments
castkarthick (4); PWSlack (1); SolarEagle (4)
