Would it be wise to install as part of the renovation to change the location a 2-way control valve from exisiting supply side of the cooling coil to the return side of the cooling coil? I have always designed chilled water piping for FCUs on the return side so that I could be assured the coil is always full as the control valve modulates. The existing system has also a reversed return. Could this be the reason why the original location was on the supply side? I have also added a balancing valve, also on the return side. Will not this be redundant considering that the reason for the reverse return is to make the system self-balancing? Any comment will be appreciated.
