Previous in Forum: Power Factor Correction for Diesel Generator   Next in Forum: How Do I Install an Automatic Timer to Control Two Exhaust Fans Alternately?
Power Output from Alternator
08/18/2012 3:54 AM
Alternator having stator(stationery part) and rotor (Rotating part) ...
Can we able to get Electrical power output from stator windings
by giving field excitation to rotor windings?
Pathfinder Tags: Alternator power output
Good Answers: 137
Re: power output from alternator
08/18/2012 6:01 AM
Yes, that's how alternators work.
08/18/2012 9:54 AM
Something must mechanically drive the rotor mechanism to get electric power out of an alternator. If the rotor doesn't spin then no electric power will be at the stator output regardless of the rotor windings excitation. This may seem like an obvious point that does not have to be considered but the rotational speed of the rotor will also change the available electric power out of the stator windings.
Re: Power Output from Alternator
08/18/2012 1:29 PM
08/20/2012 3:42 AM
Tsk, tsk!
Register to Reply 4 comments
Codemaster (1); lyn (1); PWSlack (1); redfred (1)
