Previous in Forum: Problem in DC Motor   Next in Forum: Building a Regenerative Capable Bicycle
Transmission Line Parameters
08/18/2012 10:43 AM
is power factor is constant throughout a transmission line?
Pathfinder Tags: 12345
Re: transmission line parameters
08/18/2012 10:50 AM
Do you mean throughout the cross-section of a power line, or do you mean over the length of the power line?
Your question is not clear? Do you know what the definition of power factor is?
Power factor - Wikipedia, the free encyclopedia
08/18/2012 11:10 AM
i mean that in short ac transmission line due to inductance & resistance voltage drop occurs,by that we can observe in phasor diagram different power angles at sending end & receiving end
Re: Transmission Line Parameters
08/18/2012 12:59 PM
It might be an interesting question. Maybe the phasor diagram lengths all change in proportion, with no change in angles; or maybe the angles shift a bit too. I don't know the answer, but I suspect any angular changes would be small.
08/18/2012 2:56 PM
check these about power factor
Power Factor
08/18/2012 11:03 PM
no,It is not constant in ac power line transmissoin,because of i^2*R losses and somewhere due to corona losses.
Good Answers: 44
08/21/2012 11:50 AM
It's quite easy to measure power factor through transmission lines...take measurements at your service. Of course, your distribution transformer will have some effect, so it makes the line PF almost irrelevant.
PF is more relevant to your service provider, in an event.
Nothing is "constant" in any part of an AC transmission system.
Register to Reply 6 comments
Anonymous Poster (1); cuba_pete (1); lyn (1); nobodysomebody47 (1); raju chidurala (1); Tornado (1)
