Previous in Forum: 2004 Honda Civic DX Dash Intermittent   Next in Forum: Automotive Mileage
18 comments
Cost of Automotive Parts
08/18/2012 4:14 PM
Are after market car parts as good as OEM parts?
Why are OEM parts so many times more expensive? When a car company is producing parts by the thousands and assembling those parts into a new car, I'm assuming they produce more than they need for spare parts. Whether they are used to build the car or put aside as spares, they all cost the same, so why do they cost so much more at the dealer?
Mr.Ron from South Ms.
Re: Cost of automotive parts
08/18/2012 4:21 PM
The dealer is required to stock parts for any vehicles they produce for 10 years....They only make a certain amount of spares then break down for retooling....as supplies start to dwindle the price goes up,,,and up....and up, until the part costs more than is practical thus preserving inventory and compliance....
08/18/2012 6:13 PM
Overhead.
Inventory.
Dealerships have many more thousands of square feet of warehouse than your aftermarket suppliers.
India - Member - Isloorkar
08/18/2012 10:41 PM
Overhead.
Inventory.
Greed.
Opportunism.
The marketplace runs on the " Bigger Fool " theory. In the food chain, the bigger fish gobble up the smaller fish. There is a similar smartness hierarchy in the marketplace. If you add up the individual cost of spare parts required to assemble a vehicle, most often you will end up with a figure 3x to 5x of the vehicle cost itself. And many of the parts wont be listed too.
08/18/2012 10:48 PM
Here, in the USA, we don't call it greed. It's called capitalism. It means the same thing.
Good Answers: 39
Re: Cost of Automotive Parts
08/18/2012 11:00 PM
Storage space costs money. There's a mean tax on inventory every damn year. Shipping parts around the country is expensive. Hence, just-in-time manufacturing, with aftermarket parts a whole other business with its own need for profit.
Align culture with nature...
Good Answers: 102
08/19/2012 2:19 AM
Aftermarket spare stockists have the same warehousing overheads as the vehicle manufacturer. I don't think that's the main reason.
I said vehicle manufacturer and not OEM deliberately here.
OEMs manufacture bits for both the original vehicle manufacturer and the aftermarket spares market. Generally speaking. They even produce a line of parts that have a higher spec than the original car manufacture calls for but are required for the aftermarket demand.
How often have you opened an original car brand spares carton to find the part decorated with the markings of a reputable aftermarket (OEM) manufacture? Bearings, lamps, relays, solenoids, vacuum servos, spark plugs (my favourite), brake parts..... Frequently most likely.
What the vehicle manufacturer does is provide traceability, liability, "peace of mind", convenience and warranty. These value added attributes have a value and a real cost.
Were not talking about pirated knock offs here are we? That's something else again.
08/19/2012 5:11 AM
Back in the 1980's my brother had a VW bug. The indicators stopped flashing, so he went to the dealer for a replacement unit. VW sell Bosch parts, with the VW emblem emblazoned on them - but the Bosch part no. was still visible, so "no thanks" to VW's offer at £45, and off to the Bosch distributer....£25 there, but also a generic part number on their part (where the VW logo was on theirs)..... Eventually bought for under £10 at a local Motor Factor.
This does not mean that the part was of the same quality, only came from the same supplier: Apple choose the top 5% or so (at final test) of screens for their computers, the remainder going to the next bidders.
Madness is all in the mind
08/19/2012 8:17 AM
Well made aftermarket parts can be superior to OEM as these folks are quick to spot deficiencies and make the correction. I have seen this in suspension parts, valve train parts and engine internal parts. OEM are made to spec. and sometimes these parts fail under normal use that were not detected in testing. Some years ago I had a used car and the transmission was needing repair. The transmission mechanic provided me with a list of 132 improvements their aftermarket kit had over the OEM such as die cast replacing a plastic governor housing. Even the shift points were improved and I was amazed at how the car ran and shifted gears after the overhaul and about 50% less cost than the dealer wanted for same job.. I knew this car for about 9 years and the transmission was still working as good as the day it was overhauled. As direct or near direct sellers they do not require 1000% profit to be happy.
Good Answers: 16
08/19/2012 10:47 AM
Replacement parts at the dealer are what we call cash cows, the markup is very high, this is where they make a lot of their profit, it has little to do with cost of the part, storage, shipping or anything else. The same thing exists in other markets as well, motorcycles are also terrible for high replacement part cost, this has been around for decades.
Back in the 1970s, I worked for a resistor firm, an OEM approached us to make a temperature sensor on their engines, this required a machined brass shell that screwed into the engine block, they were pushing real hard for a price well under $2.00 each, which was virtually the same as the cost of manufacturing it. We went down to the local dealer and bought one of these parts, dealer price....$20 each. The OEM was trying to get a markup of over 13 times cost from us, way beyond any total costs between us and the dealers. We gave them a bid and they went away quietly. To some degree, I vote for the greed factor, this went well beyond any reasonable profit.
I recall an article written back in the 1970s which did a cost analysis on building a car from OEM replacement parts, basically a car that retailed at under $6,000 at the dealer would end up costing nearly $70,000 in replacement parts. Given the experience we had with the OEM above (and it wasn't the only example), I could easily believe the article.
I can say that from having to buy some OEM parts for my motorcycle, it would easily cost well over 10 times what the bike cost me new and unfortunately, after-market parts are often only a little bit better on pricing although, in some cases, they are better than the OEM part.
Hobbies - Target Shooting - New Member Hobbies - Fishing - New Member
Good Answers: 12
08/19/2012 4:17 PM
Great opportunity for 3D printing of parts as needed. Soon to come. Jay Leno is already using this technology. Probably wont help the price though, at least for the near future.
08/19/2012 6:14 PM
Was in the industry for 26 years. It is the car companies and no-one else!!!!
The sell price for components to the car companies was the same as the "OE" (Original Equipment) sell price. (They argue that it must cost the same as we were charging them.) They even provided the packaging, so there was no opportunity there.
There is no volume parts storage, the component producers are required to guarantee supply for 10 years after last model use, with minimum order quantities in hundreds, seldom thousands.
They do not store significant spare parts stock, since if a design improvement happens, the spares would then be obsolete.
The component suppliers were FORCED to maintain the original prices even in that situation OR ELSE you will not be involved in negotiation for future business.
I was there during the new project so called negotiations with the car companies, including TOYOTA, GM, FORD, NISSAN and others. (I accept that CR4 administrators can remove the specifics in this paragraph if it's felt inappropriate, but these were my personal experiences.) I didn't see any company that behaved differently.
Good Answers: 266
08/20/2012 12:01 PM
These companies are mostly in the business to sell cars. If they made parts accessible relatively cheap. More customers would go for the repairs then consider replacement of the car.
08/20/2012 8:35 PM
MY suspicions have been confirmed. Thanks.
08/21/2012 3:59 AM
the simple answer is, not normally. there are a few asian countries capable of doing good metalurgy, s. korea e.g. , but for the the most part, they still don't have the technology [china]. making bearings is a good example.
08/21/2012 12:38 PM
Bearings are made with high precision machinery, not humans. Any country with the right machine can make bearings. Now if that country is making their own machines, then you are correct.
08/21/2012 10:45 PM
i disagree. i think you're only referring to the finishing proccess.
Good Answers: 102
08/21/2012 11:00 PM
The best machining in the world can't compensate for inferior or inappropriate materials.
The biggest problem with goods from developing industrial economic sources is the material. Anywhere a short cut can be taken it is. QC in these environments is if it looks good and fits it's OK. Spelling on packaging/labelling is getting better now so really hard to spot....
08/23/2012 4:35 PM
My Daihatzu Terios 1300 needed a petrolpump. The dealer price was R6009.00; I bought an after-market pump that looks and works exactly the same for R250.00..[24x more expensive].
My old Nissan 1600 needed a water-hose which was priced at 640.00 at the dealer and R63.00 at Midas in South Africa.
I think agent prices are highway robbery!
Register to Reply 18 comments
Electronic Wiz (1); GM1964 (1); isloorkar (1); jlstitt2 (2); jurie sa (1); Just an Engineer (1); lyn (2); ormondotvos (1); ozzb (1); ronseto (2); ronwagn (1); roy hammy (1); SolarEagle (1); Wal (2)
