Previous in Forum: Strength Weld   Next in Forum: Co Boiler
Boiler Feed Pump
08/22/2012 1:47 AM
can any one tell, whether the line size of balancing leak off line in BFP have any significance.
If it so, how to select the line size
Pathfinder Tags: Boiler Feed Pump
Re: Boiler feed pump
08/22/2012 4:42 AM
<...how to select the line size...>
Keep the average velocity in it between 1 and 3m/s.
09/02/2012 3:37 AM
I would size the leak -off to be about 10% of rated flow so that the temperature rise from suction to delivery in the feedwater does not exceed 9 deg F or about 4 deg C.
Register to Reply 2 comments
