I was wondering if there is a general rule of thumb for determining the maximum root gap in a fillet weld. For example, I have a stainless steel tube which is placed perpendicularly in a hole in a stainless steel plate, and due to other constraints, must be fillet welded on its OD. Normally I would specify a weld leg no greater than the wall thickness of the tube, however when one considers the dimensional tolerance of the hole and the tolerance of the tube, it becomes apparent that certain drill sizes for the hole may potentially give too much gap for an adequate weld. Unfortunately I havent been able to find a standard (ASME, for example) yet which explicitly calls out how to calculate this. Thoughts?
