Previous in Forum: Snap Locking Mechanisms in a Plastic Enclosure   Next in Forum: Control valve flange thick ness
wps
05/17/2007 3:04 AM
Iam qualifying welder as per ASME Sec-XI, Tensile test piece was broken inside weld.Is it acceptable.
Please clarify my doubt
Re: wps
05/23/2007 2:13 AM
As long as the tensile strength obtained in the test satisfies the min. requirement as per material specs. for the base material one can accept. But in general the failure occurs outside the weld material.
You must also check for bend test failures if any which will reveal defects in weld metal. The test piece for Procedure qualification should not have any unacceptable defects in weld metal confirmed by radiography / bend tests.
Reply to Forum Thread
