Previous in Forum: Difference Between Centrifugal and Axial Fans   Next in Forum: wps
Snap Locking Mechanisms in a Plastic Enclosure
05/17/2007 2:42 AM
i want to know will a deflection of 0.75mm will give a good snap locking mechanism for a force of around 100gms. it should not be very weak also. is there any guide for snap locking mechanism where a snap technique is used to lock a probe or anttenna suppose in a plastic enclosure at the extreme positions i.e., locking at fully retracted and locking at the fully extended position. what material would be suitable i have zeroed in lexan FL900P but is there any other material with better properties for impact, elevated temperature and regidity. Also what would be the force which will be practical for such probes used in handheld enclosure. please help.
Engineering Fields - Mechanical Engineering - Member Engineering Fields - Piping Design Engineering - Member United Kingdom - Member - New Member Technical Fields - Education - New Member Popular Science - Cosmology - New Member
Re: Snap Locking Mechanisms in a Plastic Enclosure
05/18/2007 3:40 AM
Guest,
I needed to look at a similar thing during a project a while back. I found this website which might be of some use to you...
http://www.engineersedge.com/snap_fit_tapered.htm
Kev Brown
Good Answers: 94
05/18/2007 5:33 AM
A lot of the plastics manufacturers like DuPont or ICI have design guides available.
You might be interested in: Shaft-hub Locking Devices, Snap Gages, Snap Fasteners
