Previous in Forum: Cubic Centimeter/Gal to PPM   Next in Forum: Pressure Drop in Piping
10 comments
api 650
08/28/2012 1:03 PM
exist a limit of capacity (volume) in API 650
I need design a tank of 300000 Barr (50 000m3) but i don`t know if i can use this standard
thanks for your help
Good Answers: 137
Re: api 650
08/28/2012 3:31 PM
Are you having a laugh? or did you hold your finger on the 0 key for a while by mistake?
Re: api 650
08/28/2012 4:31 PM
At this pressure level you don't have a pressure vessel you have an explosion in progress.
Best you recheck your units of measure.
Good Answers: 61
Re: api 650
08/29/2012 7:14 AM
He made a mistake. He did not mean "Bar" as in pressure.
He meant to write "Barrels" as in volume.
That's the trouble when people use "Text-Talk" writing in technical correspondence.
Do it once and do it right
Re: api 650
08/29/2012 9:19 AM
you are right
maybe i don't write well, I from Peru so i don't know well English
but i tried to talk about the volume 50 000m3 (300 000 barrels) and if I can use the api 650 for this capacity
Good Answers: 104
Re: api 650
08/28/2012 9:07 PM
I don't see why not - what does API 650 say? I don't have it available.
Good Answers: 137
Re: api 650
08/29/2012 4:29 AM
I think we can be fairly sure it doesn't deal with pressure 300000 bar!
Re: api 650
08/29/2012 3:22 AM
300000Bar?
Re: api 650
08/29/2012 9:22 AM
Good Answers: 61
Re: api 650
08/29/2012 11:31 AM
Jasatok,
Now that we have cleared up that you are indeed talking about capacity I have the following recommendation.
Do not use one tank of 300,000 barrels. That is the old "Putting all your eggs in one basket" syndrome. Instead I would use two 150,000 barrel tanks (150 feet in diameter by 48 feet high). At the site they should be located approximately 300 feet apart and in separate dike areas.
My reason is that with one lighting strike you can have a really big fire and lose way too much inventory.
Good Answers: 38
Re: api 650
08/29/2012 12:35 PM
As we begin this long process of finding out if the original poster has any command of English, let me ask...
- Where in the world will the tank be located ?
- What is the liquid and what is it's vapor pressure ?
- Have foundations and soil conditions been explored ? (Much to the chagrin of the third-world, You can't put any tank anywhere !)
Please, do not use urban "text-talk"....long descriptive sentences are best ! !
Register to Reply 10 comments
bigg (1); Codemaster (2); jack of all trades (1); jasatok (2); MJCronin (1); PennPiper (2); PWSlack (1)
