Previous in Forum: Need Help to Understand a Parameter of Parker HPC Servo Drive   Next in Forum: Battery Charging Controller
DC Voltage Step - Down
09/02/2012 4:07 AM
Dear Engineers,
Please tell me a way, if there is one, to step down DC voltage to a customised voltage.
Good Answers: 34
Re: DC Voltage step - down
09/02/2012 4:15 AM
You can have a customised, variable, voltage regulator to get required step down DC voltage.
09/02/2012 5:15 AM
Simplest - resistive divider: Only gives constant voltage out for constant supply voltage and constant load. Power lost = voltage dropped across resistors x current through them.
Adjustable linear regulator: Mostly independent of supply voltage and load current. Power lost = voltage dropped across regulator x current through it.
Adjustable switching regulator: Mostly independent of supply voltage and load current. Little power lost. May have switching noise on output unless well filtered.
Re: DC Voltage Step - Down
09/03/2012 3:20 AM
09/03/2012 5:02 AM
Thought that was a switching regulator .
Register to Reply 4 comments
JohnDG (2); Joshi (1); PWSlack (1)
