Previous in Forum: Vaccum Pulling in a 135 MW Steam Turbine   Next in Forum: HVAC Information
13 comments
Reduction Worm Gear Back Driving
09/02/2012 12:18 PM
We have fabricated a passenger lift and used 3 Ph, 3 HP motor, 4" EM brake, and have used speed reduction in the ration of 1: 9, through pulley and belts.
The lift goes up comfortably, but while descending it catches high speed, which is not desirable.
Option left with us is to use Reduction worm gear drive, in place of pulley and belts. But with such low ratio, there seems to be tendency of back driving, as self locking will not be effective. This problem had happened with us in some other project also.
As per general specification table the recommended gear box is of 3" for 1:10 ratio. I would like to know, how the lead angle will be less than 5, as suggested to be safe from back driving. In my opinion with larger dia and lesser ratio the lead angel will be more. But small gear box say of 2" or less will not be strong enough to hold the load.
Re: Reduction Worm Gear Back Driving
09/02/2012 1:05 PM
Do you have a counter balance setup?
Good Answers: 114
09/02/2012 1:19 PM
I agree with SE.
If you don't have a counterweight you can expect this behavior. In one direction the elevator weight works against the motor, slowing it, in the other, it works with the motor, speeding it up. It is also safer with the counterweight.
09/02/2012 1:56 PM
Good Answers: 299
09/02/2012 2:33 PM
I agree with lyn.
This venture is likely to end in tears... equally likely to land someone in prison.
09/02/2012 3:26 PM
I doubt that any jurisdiction would consider worm gears, even of low lead angle, to be adequate as a brake. You still could equip the motor with a brake, though. A faster motor with larger worm gear ratio might also help. These are just some ideas; there may be a local Code that must be followed carefully.
09/02/2012 8:27 PM
yes, use a worm gear that machined properly,
your lift should have been tested with a dead load that was heavier than any possible passenger load.
CR4 ADMIN: Modified Post
Abuse/Attack: This post was modified because it contained an attack on another user. Please review the CR4 Site FAQ and the CR4 Rules of Conduct.
09/02/2012 8:49 PM
You are the last one here who should call anyone an "ignorant asshole".
And, if that does'nt make any sense to you, it won't surprise me.
09/02/2012 8:58 PM
What an unfriendly answer to a first time poster. You should be ashamed of yourself and your answer is not worth anything the way it is written.
09/02/2012 11:52 PM
09/03/2012 12:12 AM
CR4 ADMIN: Deleted Post
Irrelevant This post was deleted because it is related to a deleted post and would otherwise be taken out of context.
09/04/2012 12:44 AM
Thanks for varied replies.
Well there is no counter weight, and also I am aware of this procedure.
But my asking the question is to discuss and find out possible way to sort out a new type of situation. Always there is a scope for innovation with a new problem. I expect a real brain teasers here, not just a commonsense.
09/04/2012 3:49 AM
i repent for my sarcastic remarks. your major consideration must be the safety of the passengers. you can't throw a bunch of junk you happen to have laying around and expext to have a safe passenger hoist.
i know this from several very bad experiances involving a 1,000' smoke stack.
i think you should revue the ottis elevator design.
passenger safety should always be the first consideration.
09/04/2012 12:56 PM
You are right,but there is very limited space,and passenger lift was necessary,so counter weight could not be added. Certainly safety is prime consideration,it can not be compromised
Register to Reply 13 comments
BHPINDER SINGH (2); Doorman (1); durtieduck (3); IdeaSmith (1); lyn (2); passingtongreen (1); SolarEagle (1); Tornado (2)
