Previous in Forum: Battery Charging Controller   Next in Forum: Separate Transformer in Lighting Panel?
HLR Breaker with BLG Mechanism Trip Delay
09/02/2012 12:18 PM
When testing the 138kv HLR breaker with BLG mechanism with the full rated control DC power supply 130VDC the trip time 32millisecond it is good the spec is 34millisec. +/- 4 milliseconds.
According to the IEEE guideline, the breaker tested with 70VDC the breaker didn't trip. Tested with 75VDC the trip took 70 milliseconds, out of the spec. range.
Now is it a coil problem or the mechanical lubrication problem? Any one has this experience before
thanks
Re: HLR Breaker with BLG Mechanism Trip Delay
09/02/2012 11:35 PM
90% is a coil problem.
Coil is not operating the plunger at 70 Volt DC.
Coil shoukl have a lower resistance to offer more current at 70 V DC.
Good Answers: 34
09/05/2012 4:27 AM
Most likely, it is mechanical friction problem. Only good remedy is replacement.
