Previous in Forum: Martensite or High Carbon Steel?   Next in Forum: Helium Leak Detectors and Helium requirements
14 comments
Fiber optic interface with assorted block plastics
05/17/2007 9:59 AM
I am interested in interfacing fiberoptic cable with a block of plexiglass (or other plastics) in order to transmit an image via (say cctv or digital video) through the cable into the plexiglass block. I am having trouble finding out (a) if this has been done before and (b) if not, how to get the specs correctly. I am a mathematical physicist so the mathematics and the physics is not the problem, it's the engineering that's killing me. Any help would be greatly appreciated.
Re: Fiber optic interface with assorted block plastics
05/17/2007 7:47 PM
I think we have the same problem, If you have any ideas let me know, check out my question. Thanks
Bill
05/19/2007 4:27 PM
Will do Bill. But it appears that the dialogue has taken a left turn into insanity. I have reported the two posters. I have the feeling that I will get no responses.
United States - Member - Donald here, Campbell Lighting Co. Engineering Fields - Retired Engineers / Mentors - New Member
05/17/2007 11:47 PM
I will ask that question to my Fiber Optics manufacturer... then let you know..
Donald
Check out our home page for specs on "Soft Neon"
05/19/2007 4:29 PM
Thank you Donald. I appreciate the effort. I look forward to hearing what you find out. I don't see that the thread will yield much response as it appears to have take a left turn into insanity.
05/18/2007 3:19 AM
try this link www.howstuffworks.com then search how fiber optical work
maufi
05/19/2007 4:24 PM
what is that comment about white women. Now I am being accused of being racist because of your post. I am reporting you.
05/19/2007 5:08 PM
Not You, Tarynn, I meant the guy that said 'No White Women" was being racist..
05/21/2007 4:40 PM
OK ... Thanks.
Tarynn
Good Answers: 94
05/18/2007 5:46 AM
I don't know if this has been tried but I would imagine that you would need to expand the image from the fibre bundle using a fibre optic taper. Someone like Edmunds Optics would stock a range of tapers.
05/19/2007 4:37 PM
Thank you for responding. I will look into this in greater detail. If you have any links of use, that would be a great help.
Good Answers: 94
05/21/2007 4:43 AM
Try here http://www.edmundoptics.com/onlinecatalog/displayproduct.cfm?productID=1599&search=1 These are an 'off the shelf' supplier who have a limited range of tapers. Other suppliers like http://www.incomusa.com/ or http://www.schott.com/uk/english/index.html will make custom shapes but will be expensive & have long lead times. If you are just experimenting it's always worth begging to see if they have any rejects that they might give away.
05/21/2007 4:59 PM
Thank you so much. Great links. I will see what I find and keep the group informed.
Tarynn
05/19/2007 2:58 PM
Hi Everyone-
Thanks for the input. By the way, what was the comment about white women about?
Tarynn
05/19/2007 3:07 PM
I agree Tarynn sounds racist to me...
Register to Reply 14 comments
Anonymous Poster (2); Campbell Lighting (1); maufi (1); Nigh (2); ryliescience (1); tmwitten (7)
