Previous in Forum: Roof Top Pipe Support Help   Next in Forum: Friction Gears
Turbo-Charger for cooling.
05/17/2007 11:30 AM
In some models of aircrafts e.g. Embraer 120 ER, cool conditioned air is produced by a component called Air Cycle Machine. This component is similar to the Turbo-Chargers in some classes of automobile. The visual similarity is in the fact that both have the turbine and compressor on one shaft and encased in one single housing. My question is , can I make use of a fairly used turbo-charger unit to build an airconditioning system that will use only air as its working fluid? Better still, can I have a little refrigerator using this key component? Friends, can you give me a workable simple but practical design. Supply of parts would be from the junkyard. I am located in a third world country where money is hard to come by. Please make it cheap.
Popular Science - Weaponology - New Member United States - Member - New Member Engineering Fields - Automotive Engineering - ChemE in a ME world
Re: Turbo-Charger for cooling.
05/17/2007 1:18 PM
I beleive the that the exaust is still the "working fluid" and you are scavaging energy from the engine. Where will your energy come from? The Cooling comes from the JT effect of the expanding gas so you will have to put energy into the system to compress the air.
No matter how far you have gone down the wrong path....Turn around!
05/17/2007 11:44 PM
the kinetics is teh oldest form of working refrigeration, but quite simple.
the turbo charger bit is not the same as a car type the turbine input comes form the engine, hot exhaust gases, which then dump to atmoshpere the compressor picks up clean outside air and compresses it, leaving it hot. It is then cooled by air to air intercooler (still under pressure) then realeased through ventury nozzles into the cabin space reducing pressure and lowering the ambient inside temperature to fuel its expansion.
All you need is a compressor unit and drive. If you have a V8 or VW engine you can regrind the cams to use half pistons as motor and half as compressor ( alternatively replace half teh valves with self opening units) Black Poly pipe is ok for pressure side to nozzles. a coil of metal pipe or a series of old car aircon condensor coils immersed in water or buried in wet soil will work as the heat exchanger/cooler. On teh compressor side you can replace the piston rings with neoprene O-rings. You can also drive the whole thing from water wheels or place a piston air pump onto a windmill. you will need a very large pressure tank . Try used plastic bottles, clamp the screwcap on with a pipe bandclamp so it doesn't pop off.
You could use the turbo compressor by belt driving it from a large wheel such as a bicycle wheel rim wired to a windmill turbine to the center of teh shaft (leather belt or womens pantyhose belt (less woman)
apologies for the crook spelling.
05/18/2007 9:06 AM
Try a Ranke/Hilsch tube. No moving parts, just supply it with compressed air and get cold air from one end and hot air from the other. Simple to build and fairly efficient and not quite as noisy as the turbine but please do wear ear protection when experimenting with either.
intellectuals solve problems, geniuses prevent them ~ Einstein
Good Answers: 32
05/18/2007 11:54 AM
These are commonly called Votex tubes. Here is one commercial device:
http://www.arizonavortex.com/vortex-tube/
Location: Bolingbrook Illinois, a southwest suburb of Chicago.
05/20/2007 1:45 PM
It's called the Coleman refrigeration cycle, from ships, circa 1920
"People find it easier to forgive you for being wrong than for being right" J K Rawlings
Anonymous Poster (1); NoSciFi (1); Tad (1); taejonkwando (1); Yani (1)
