Previous in Forum: File in XP to Windows 7 (txt / exe)   Next in Forum: Computer Question
DELTA PLC: High Speed Counter in Ladder Diagram
09/07/2012 11:32 AM
I am trying to program a PLC (Programmable Logic Controller), Model: DELTA, ES2 series, in Ladder Programing mode.
I need to use a High speed counter, (C235, using X0 pulses) but could not find a clear explanation in the DELTA Manual or their software program, WPLSoft ver 2.20.11
Can anyone write a small routine, that uses the above C235, that will definitely work as a trial?
Can I use the simulator to try it?
Thanks
LAA
Re: DELTA PLC: High Speed Counter in Ladder Diagram
09/08/2012 5:37 PM
Thanks Joshi for the links.
09/09/2012 6:23 AM
kindly attach here the schematic of counter to see if it is with enabling/dir+ or dir-
love4everyone
09/09/2012 7:14 AM
It is irrelevant.
This is a PLC internal counter, using the X0 input as impulse, related to the C235 counter.
How do you write the ladder diagram circuit to be able to use it correctly? And Can we use the Simulator of the Delta Software to simulate it?
thanks
Good Answers: 34
09/09/2012 8:56 AM
"Can we use the Simulator of the Delta Software to simulate it?"
Yes, of course. Why not?
08/29/2013 4:55 AM
@sohail
hi,, its long time to go,, did you find the solution? these days i need to program Delta dvp24ex200r for reading 4 high speed counters with +/- direction..can you help?
i have done 2 hi speed counting but when i add 2 more hi speed counters it gives an error.
thank you
05/07/2015 2:49 AM
Do you want a clear explanation or software for a delta PLC? Recommend a site FastToBuy.com for you, there are many industry automation products munuals with a PDF format for Free Download, yes, it's free download! http://www.fasttobuy.com/pdf2.php
if you can not find it, you can ask its customer service for help.
Register to Reply 6 comments
DavidJohnLee (1); Joshi (1); LAA_Lucke (2); mkashifk (1); sohail0110 (1)
