Previous in Forum: LED Driver   Next in Forum: Passenger Elevators
10 comments
Contactor Continuity Question
09/09/2012 12:39 PM
Hey all
I am still fresh here. I just had one 3 phase induction motor. Connected in delta. Tried to run but was making some sound but it was not spinning. I doubted the contactor for single phasing. I switced off the power and the checked continuity( by pressing the contactor) between l1 and t1 l2, t2 ,l3 t3 of the contactor .I heard the beep so I assumed it was ok but when my senior came.He checked the resistance not continity it was showing mega ohms .wth. How can multimeter beep with megaohms.
PS; relaced contactor and we had our motor running
Good Answers: 34
Re: Contactor continuity question
09/09/2012 1:20 PM
If what you state is correct, then what you observed, ie. (How can multimeter beep with megaohms) can not be true. You must have missed something.
Re: Contactor Continuity Question
09/09/2012 3:16 PM
Continuity is a good first indicator tool but doesn't tell you the full story sometimes (sometimes the continuity setting can be fooled).
If you open up the old contactor you will probably find the contact points to be burnt causing an intermittent or poor connection, and if you retest by pressing the contactor contacts together a few times some tests may show high resistance while some tests show low resistance (intermittent contact).
09/09/2012 8:30 PM
@jack,
you are right. I checked the contactor now. Sometimes shows high and some times low resistance,.
09/09/2012 8:37 PM
I have been there before, and it's not the sort of thing they adequately prepare you for in any education course. Somethings must be learnt the hard way - through simple trial and error.
09/10/2012 3:33 AM
Replace it.
Destroy the old one mechanically so that it cannot be selected for re-use.
Good Answers: 266
09/10/2012 7:38 AM
In many years of repairing electromotive equipment this problem was common. I would check for a load drop across the contacts. Making and breaking them several times to see if it changed.
09/09/2012 4:47 PM
You should not rely on the beep, but check the actual resistance.Depending on your set up the are better ways to test than pressing the contactor.
Good Answers: 50
09/09/2012 8:36 PM
How often does this motor run? How many watts?
Where is the location of the contactor? Protected from weather, mainly condensing humidity?
What voltage is the system?
I've seen contactors on outdoor condensing units that sit over the winter, and then the compressor does not start in the summer. They corrode and even though smooth not damaged contacts, the oxide prevents (in this case 240VAC) to break through this insulating oxide.
As another poster indicated, inspect the contacts for arching damage.
ignator -
Good Answers: 39
09/10/2012 2:18 AM
Teeny red ants will self-immolate, like tiny worshippers at the shrine of silver contacts. For some reason they're attracted to the contacts, usually on espresso machines. This was in Key West. Must have fixed twenty machine by simply using a matchbook cover to remove their chitinous remains.
Align culture with nature...
09/10/2012 11:20 PM
Your continuity meter should only beep at below 100 ohms but it could be faulty so always check what the reading is on the display. Another thing I have noticed when pushing the contactor in manually you can get good readings & when the contactor is pulling in under it's own power the contacts don't make correctly if they are damaged.
Register to Reply 10 comments
brettj1au (1); eltech (1); ignator (1); jack of all trades (2); Joshi (1); ormondotvos (1); ozzb (1); plckid (1); PWSlack (1)
