Previous in Forum: Starting Current & Switch Rating   Next in Forum: Selecting a Brake Rectifier?
Design LT Panel Switch Rating
09/16/2012 2:11 PM
how to decide incoming & out going switch rating in LT panel. How to select where to use switch fuse unit & fuse switch unit.
Re: design LT panel switch rating
09/16/2012 2:15 PM
It's usually in the text book.SECTION V ELECTRICAL SPECIFICATION
09/16/2012 3:23 PM
Find ISxxxx that is counterpart to BS7671 or the U.S. NEC; it should tell you the acceptable options.
09/16/2012 4:10 PM
It rather depends upon the cable sizing, and what's upstream and downstream of it, Mildred.
Good moaning!
India - Member - New Member
Good Answers: 164
09/16/2012 5:43 PM
What, in your opinion, is the difference between the two (SwitchFuse and FuseSwitch)?
If you glance at IEC 60947-3 you will see that the two terms are no longer in use. The correct term for both is Fuse-combination-unit.
So, your question is redundant. It is the same equipment both at Incoming and outgoing, only the ratings will be different obviously.
Good Answers: 170
Re: Design LT Panel Switch Rating
09/17/2012 9:20 AM
Both SFU & FSU have become almost obsolete now. Today, the most popular is the SDF Unit or the Switch Disconnector Fuse Unit.
Crabtree (1); electricalexpert65 (1); kvsridhar (1); lyn (1); Tornado (1)
