Previous in Forum: Helium Leak Detectors and Helium requirements   Next in Forum: Pipe and tube
Influence of surface activation using titanium phosphate prior to Zn phosphate
05/18/2007 3:14 AM
Any one help me,
we r bonding rubber with metal surfaces,
that metal is treated before bonding
our processes
alkaline degreasing-Zn phosphating-Dipping in bonding agent-matal and rubber bonding
suggesion required for
alkaline degreasing-surface activation using titanium phosphate-Zn phosphating-Dipping in bonding agent-matal and rubber bonding
i would like to knoe the influence of titanium phosphate on rubber bonding process and chemical composition for surface activation process
Re: Influence of surface activation using titanium phosphate prior to Zn phosphate
05/18/2007 11:15 PM
By using the titanium package prior to the zinc phosphate, the titanium actually helps promote more of a starting "landing conversion point site" for the zinc phosphate conversion coating on a clean part. This allows a more controlled formation of the zinc phosphate as compared to a larger yet fewer zinc crystal conversion coating on a application that would not use the titanium package. Zinc crystal deposition rate and quality of the conversion coating is greatly enhanced in most cases with a smaller denser conversion coat as compared to a larger irregular shaped conversion coat.
Good Answers: 50
05/19/2007 12:53 AM
Crap! This is pretty esoteric stuff! Do you work in plating? Do many customers try to plate metal over rubber?
Popular Science - Weaponology - New Member United States - Member - New Member Engineering Fields - Automotive Engineering - ChemE in a ME world
05/21/2007 7:17 AM
Guest
Are you saying that the Titanium provides more nucleation sites for the Zn to crystalize on and therefore the reaction will proceed quicker limiting the Zn Crystal size?
No matter how far you have gone down the wrong path....Turn around!
Anonymous Poster (1); vermin (1); Yani (1)
