Previous in Forum: Influence of surface activation using titanium phosphate prior to Zn phosphate   Next in Forum: Aluminium and Dangerous Thermite Action?
13 comments
Pipe and tube
05/18/2007 4:55 AM
Hallo
What are distinguishing features between pipe and tube?
What are applications where one is preferred over the other.
Re: Pipe and tube
05/18/2007 5:10 AM
Tube is generally considered to be much smaller than pipe but in essence they are both the same in make up.Tube is generally and widely used for pneumatics and hydraulics in instrument control systems and it comes in small internal diameters from as little as 1/16" up to 3/4".Remember the smaller you go then the greater the pressure it can withstand as the medium has less surface area acting on the wall of the pipe tube.This also depends upon the wall thickness and the type of material used during manufacture.Pipefitters have a blue book which may be available online this would probably explain the differences and uses better than me.
BOUNTY HUNTERS ARE DANCING ALL AROUND ME.
Re: Pipe and tube
05/18/2007 8:09 AM
VISIT SWAGELOK.COM
United States - Member - Go Tigers! Engineering Fields - Mechanical Engineering - Specialty - Mechanical Vibrations Fans of Old Computers - UNIVAC - Man I shoulda bought a Whirlwind!
Re: Pipe and tube
05/18/2007 11:27 PM
Joseph,
I've had very good experiences using Swagelok products in hydraulic applications!
fm!
"Your theory is crazy, but it's not crazy enough to be true." - Niels Bohr
Good Answers: 266
Re: Pipe and tube
05/18/2007 9:06 AM
Pipe is generally dimensioned on it ID for fluid handling purpose. It has different sizes of wall thickness called schedules which rate its pressure capability's. Tubing is by it's ID with listed wall thickness
Good Answers: 27
Re: Pipe and tube
05/18/2007 10:42 AM
Just to amplify a bit, pipe is produced to standard pipe sizes (called IPS, or Iron Pipe Size) of various schedule numbers. All pipes of a given IPS have the same outside diameter while the schedule number defines the wall thickness. For example, all standard 2" IPS pipe (regardless of material) has a nominal outside diameter of 2.375" and is normally available in schedule numbers from 5S (.065" wall) to XX (.436" wall). The most commonly used schedule is 40 (.154" wall).
Re: Pipe and tube
05/20/2007 8:27 AM
Pipe above 12" is measured by the actual O.D.
Re: Pipe and tube
05/18/2007 11:48 AM
HI,
GENERALY TUBE SIZE IS SPECIFIED BY IT'S OD. AND PIPE SIZE IS SPECIFIED
BY NOMINAL SIZE (NW/DN/IPS).
EXAMPLE: 1"TUBE IS HAVING OUTSIDE DIA. 25.4mm /1".WHERE AS
1" NW (NOMINAL SIZE) IS HAVING OUTSIDE DIA.33.4mm /1.315"
TUBE AND PIPE BOTH ARE HOLLO AND CILINDRICAL MADE IN VETIUS
MATERIAL. BOTH CAN BE EITHER SEEMLESS OR WELDED. FOR PIE NW AND SCH. NO
IS REQUIR TO SPECIFY.
Australia - Member - New Member Popular Science - Cosmology - New Member Hobbies - Fishing - New Member
Re: Pipe and tube
05/24/2007 1:38 AM
FYI. Capital letters indicate shouting. No need to yell, we can hear you just fine.
If you don't laugh, you cry.
Re: Pipe and tube
05/19/2007 5:50 AM
What is(are) distinguishing feature(s) between pipe and tube?
I used to ask this question at the beginning of my lectures concerning piping design, fabrication, inspection and stress analysis. Till now, I didn't found the engineer who has the sound reply.
The following definitions are the optimum and actual distinguishing features between pipe & tube :
Pipe is manufactured to standard dimensions, sizes, and standard thicknesses designated as "Schedules".
In all standard sizes the OD remains constant regardless of thickness. In sizes up to and including 12" the size refers to the nominal inside diameter, and in sizes 14" and larger the size denotes the actual OD.
Tube, not including furnace or exchanger tubes, is similar to pipe, but is manufactured in many sizes of outside diameters and wall thicknesses.
Good Answers: 61
Re: Pipe and tube
05/19/2007 12:02 PM
Try this website for a pretty good discussion about Pipe and Tubing.
http://www.pipingdesigners.com/Training%20-%20section%201b.htm
Do it once and do it right
NOROS
05/19/2007 9:11 PM
I use tubes in exchangers and boilers whose thickness are called BWG but IPS designation for pipes are called Schedules.Tickness and outside diameters are diferent in both cases (see the other responses above)
Good Answers: 18
Re: NOROS
05/21/2007 12:22 AM
tube Vs Pipe :
Tube differs from the Pipe in that it does not have the more liberal tollerances for inside daimeter, outside diameter, wall thickness and nominal sizes given to the pipe.
Pipe sizes upto 12 inches ( 300 mm ) are designated by nominal sizes which are smaller of the pipe; where as, in most cases, tubes are identical to the outside daimeter of the tube.
Tubing is clasified in to three major types.: structural tube, mechanical tube and pressure tube.
structural generally used for building constructioon, roadway median barriers and available in round, square,rectangle or special shapes.
Mechanical tubes is used in variety of mechanical / structural work and like in structural tube, it is not intended to carry fluids or gases under pressure.
Pressure tubes is the type of tubing used often in the piping industry and designed to carry fluids gasses under pressure.
sizing is customarilly desingned by the tube's actual outside daimeter and wall thickness or tube gauge given in either: ASTM standards cover ferrous and non ferrous in both welded or seamless forms.
Maximum sizes normally extended upto 24 inches( 609.4 mm) for round tubing with wall thickness upro 1 inch ( 25.4 mm). Structural tubing can also be made provided they meet ASTM or equicaalent specifications.
Sridhar
What we have done for ourselves alone dies with us: while what we have done for other and the society remains and is immortal.
Re: Pipe and tube
05/21/2007 6:06 PM
The optimum definition still the following:
That means that if you have a pipe produced with a size and wall thickness not in accordance with the standard dimensions, this thing can't be nominated as a pipe, it shall be a tube, whatever its diameter or thickness. The only exception is the tubes used for furnaces and heat exchangers which produced to a standards thickness and outside diameters.
Abdel Halim Galala (2); Anonymous Poster (1); Bluestone (1); fattmaxx (1); geomech (1); jmart23 (1); Joseph Cowan (2); ozzb (1); PennPiper (1); SRIDHAR (1); vidyadhar deodhar (1)
