Previous in Forum: Crower's Six Stroke Engine   Next in Forum: Hydro Test of Lines
Pulsation Dampener Selection
09/19/2012 12:17 PM
I am looking to know if a pulsation dampener is always recommended for a pulsating pump (e.g reciprocating). If not, what is the rule of design on the basis of flow, pressure, etc?
Appreciate your comments!
Pathfinder Tags: pulsation dampener
Good Answers: 92
Re: Pulsation Dampener Selection
09/19/2012 10:21 PM
Rules of thumb for pulsation dampening on pumps:
  1. Your pump supplier will gladly recommend one to go with the pump he wants to sell you.
  2. You actually only need it if you need it.This is not normally determined by flow or pressure as much as it is determined by process needs to even out the flow or mechanical stresses on the associated piping etc. from the pulsations. Figure this out & you have your answer.
09/19/2012 11:58 PM
The reciprocating pumps, by virtue of their inherent design, results in pressure pulsation in the discharge flow.
The pulsation dampeners at the diascharge is essential to suppress the pressure pulsations, for maitaining a steady state accuracy for flow in case of dosing applications as well as to avoid damage to the discharge piping and instruments due to vibration induced by pressure pulsation.
The sizing is dictated by the permissible residual pulsation dictated by codes and is generally designed/selected and supplied by the pump supplier, in case of order.
Usually, a small air vessel /or off-the shelf bladder type accumulator (precharged type, in case of high pressure) is supplied by the pump supplier that is mounted in the discharge piping just downstream of pump discharge.
Hope this helps.
King cow Protector
Good Answers: 102
09/20/2012 1:35 AM
You need the pressure vessel for delivery systems that may be subjected to restriction on the discharge so you don't break the pump in the event of a dead head.
If there is no restriction or high head on the discharge the dampener won't do a thing and you'll still have a pulsed discharge flow.
Register to Reply 3 comments
JNB (1); Kingcow Protector (1); Wal (1)
