Previous in Forum: Radiated Emissions of 480/277 Motors   Next in Forum: Control Projects
Lighting and Distribution
09/20/2012 9:41 AM
1 What is the effect of supplying a 220V 50Hz AC Incandescent lamp to any DC source
2 Why do we use parallel groove clamps when connecting a copper cable to an overhead aluminum conductor
Re: Lighting and Distribution
09/20/2012 10:22 AM
A1) Very little, other than it won't flicker at 50Hz.
A2) So that a clean-and-tight connection ensues. What else would one do - a tape-joint?
09/20/2012 11:59 PM
What will happen if you supply ac power via a half-wave rectifier to an incandescent or to a ballast operated lamp(fluorescent,mercury,sodium,MH,induction,LED,CFL etc)
pnaban
Good Answers: 34
09/21/2012 3:48 AM
One half cycle will be missing in the DC out put, thereby the out put voltage will be half of AC input voltage.
09/21/2012 6:43 AM
I meant how it will affect the lumen output of the lamp and will it appear to be flickering?.
pnaban
Good Answers: 34
09/21/2012 6:58 AM
Lumen output of the lamp will be reduced, not sure by how much. Yes, it will appear to be flickering.
09/21/2012 7:12 AM
Is it a guess,did you try it,can you give figures?.
pnaban
Good Answers: 34
09/20/2012 11:35 AM
answer to
2. To keep the dissimilar metals separate.
Register to Reply 7 comments
Joshi (3); pnaban (3); PWSlack (1)
